LPCXpresso-IDE is hanging
lpcware
Content originally posted in LPCWare by glissov on Thu Nov 17 06:13:23 MST 2011
I have a problem with LPCXpresso-IDE hanging when making a build, clean or debug. I have Win 7 32 bit and  LPCXpresso v4.1.0 [Build 190] [27/09/2011] .
There are no difference between Debug or Release mode and it does not happen if I continously build. But if I haven't build my project for say 60 seconds it will happen again. The IDE is hanging around 40 seconds.
The following link is to a guy which had the same problem last year:
http://knowledgebase.nxp.com/showthread.php?t=416
Please let me now if there has been found a solution. I have tried a thousand things and nothing seems to cure the problem. It is very frustrating to wait 40 seconds nearly every time you have to build.
