LPCXpresso Free activation error
lpcware
Content originally posted in LPCWare by aferrari on Wed Jul 29 06:06:09 MST 2015
Hello everyone,
I've tried to activate the Free Edition license for LPCXpresso (v. 7.0.2), but an error has been arisen.
I haven't an internet connection on the PC with the LPCXpresso installed, so I did the following:
1) from LPCXpresso "Help->Activate->Create serial number and register", I obtained the Serial Number
2) I copied this serial number in the "LPCXpresso Key Activation" page; this page gave me the "LPCXpresso Activatiion Key"
3) I put this key in LPCXpresso  "Help->Enter Activation Code"
At this point LPCXpresso gave me the error "No license to activate".
Where I'm wrong?
Thanks in advance
Alberto
lpcware
Content originally posted in LPCWare by aferrari on Thu Jul 30 03:33:01 MST 2015
Dear Support,
I don't know what has happened, but I've just tried the activation again and it has gone fine  !!!
Now I'm able to work with the Full License.
Thanks again for your help and your effort.
Have a nice day.
Alberto
lpcware
Content originally posted in LPCWare by aferrari on Thu Jul 30 03:24:50 MST 2015
I followed the activation procedure as reported in "LCPXpresso User Guide, rev. 7 10 March, 2014" at pag. 10, point 2.5 "Activating your product (LPCXpresso Free Edition).
This morning I've done the procedure again. These are the serial number and the activation code:
Product Serial Number
GXNQ-DZJ0-K0I4-CZC1-F1LX-CQA0-FRN5-GSOQ-P1JY-PSEQ
Product Activation Key
HRE2-OWHU-F3HU-I3FW-D1AT-BVNZ-MZK3-J0F0
but the result has been the same (no activation)
Please remember that the PC has no internet connection.
I've also tried the activation on another PC that has a internet connection and in this case the procedure was fine.
I hope this could help you to give me some others hints.
Here the content of the .log file
!SESSION 2013-11-28 11:13:04.328 -----------------------------------------------
eclipse.buildId=Release 14.5 Build SDK_P.58f
java.version=1.6.0_21
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 2 0 2013-11-28 11:13:45.656
!MESSAGE Warnings while parsing the viewer contributions from the 'org.eclipse.ui.popupMenus' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2013-11-28 11:13:45.656
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.CBreakpointPropertiesRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.EnableDisableBreakpointRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.ui.actions.RulerCreateBreakpointInteractiveAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.CBreakpointPropertiesRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.EnableDisableBreakpointRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.ui.actions.asm.RulerCreateBreakpointInteractiveAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='AUTOGEN:::org.eclipse.cdt.dsf.debug.ui.disassemblyRulerActions/org.eclipse.debug.ui.actions.RulerAddBreakpointAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='org.eclipse.cdt.dsf.debug.ui.disassembly.commands.rulerToggleBreakpoint'
Thanks for your help.
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Thu Jul 30 00:47:00 MST 2015
I'm sorry, but I have no idea what is causing your problem. Are you certain that you followed the process exactly as documented in the User Manual?
I suggest that you try the whole activation process again, and document each step, together with the serial number, activation code, and and errors received, and post here.
Finally, can you also post the log file from
(your_workspace)\.metadata\.log
lpcware
Content originally posted in LPCWare by aferrari on Thu Jul 30 00:17:33 MST 2015
ok here the output
Microsoft Windows XP [Versione 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\aferrari>cscript
Microsoft (R) Windows Script Host Versione 5.7
Copyright (C) Microsoft Corporation 1996-2001. Tutti i diritti riservati.
Sintassi: CScript scriptname.extension [option...] [arguments...]
Opzioni:
//B            Modalità batch: Impedisce la visualizzazione di errori e prompt di script
//D            Abilita il debug attivo
//E:engine     Utilizza il motore per l'esecuzione dello script
//H:CScript    Cambia l'interprete di script predefinito in CScript.exe
//H:WScript    Cambia l'interprete di script predefinito in WScript.exe (predefinito)
//I            Modalità interattiva (predefinita, opposto di //B)
//Job:xxxx     Esegue un processo WSF
//Logo         Visualizza il logo (predefinito)
//Nologo       Impedisce la visualizzazione del logo: al momento dell'esecuzione non verrà visualizzata alcuna intestazione
//S            Salva le opzioni della linea di comando correnti per questo utente
//T:nn         Timeout in secondi: tempo massimo consentito di esecuzione di uno script
//X            Esegue lo script nel debugger
//U            Utilizza Unicode per I/O reindirizzato dalla console
C:\Documents and Settings\aferrari>ipconfig/all
Configurazione IP di Windows
        Nome host . . . . . . . . . . . . . . : lab12
        Suffisso DNS primario  . . . . . . .  :
        Tipo nodo . . . . . . . . .  : Sconosciuto
        Routing IP abilitato. . . . . . . . . : No
        Proxy WINS abilitato . . . . . . . .  : No
Scheda Ethernet Connessione alla rete locale (LAN):
        Suffisso DNS specifico per connessione:
        Descrizione . . . . . . . . . . . . . : Intel(R) 82579V Gigabit Network Connection
        Indirizzo fisico. . . . . . . . . . . : E0-69-95-D2-CF-EC
        DHCP abilitato. . . . . . . . . . . . : No
        Indirizzo IP. . . . . . . . . . . . . : 192.168.146.52
        Subnet mask . . . . . . . . . . . . . : 255.255.255.0
        Indirizzo IP. . . . . . . . . . . . . : 192.168.50.76
        Indirizzo IP. . . . . . . . . . . . . : 192.168.46.76
        Indirizzo IP. . . . . . . . . . . . . : 192.168.35.76
        Indirizzo IP. . . . . . . . . . . . . : 192.168.25.76
        Indirizzo IP. . . . . . . . . . . . . : 192.168.8.76
        Indirizzo IP. . . . . . . . . . . . . : 192.168.7.76
        Indirizzo IP. . . . . . . . . . . . . : 192.168.1.76
        Gateway predefinito . . . . . . . . . : 192.168.1.228
C:\Documents and Settings\aferrari>wmic process get name
Name
System Idle Process
System
smss.exe
csrss.exe
winlogon.exe
services.exe
lsass.exe
svchost.exe
svchost.exe
svchost.exe
svchost.exe
svchost.exe
spoolsv.exe
DtapiService.exe
hasplms.exe
IPROSetMonitor.exe
LMS.exe
sqlservr.exe
explorer.exe
sqlwriter.exe
UNS.exe
igfxtray.exe
hkcmd.exe
igfxpers.exe
RTHDCPL.EXE
nusb3mon.exe
jusched.exe
ctfmon.exe
alg.exe
wscntfy.exe
das_dashpas.exe
das_server_usb11_jtag_over_usb_box.exe
svchost.exe
Eurotek MST.exe
Eurotek MST.exe
csrss.exe
winlogon.exe
rdpclip.exe
logonui.exe
logon.scr
javaw.exe
AcroRd32.exe
AcroRd32.exe
javaw.exe
lpcxpresso.exe
cmd.exe
wmic.exe
wmiprvse.exe
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Jul 29 09:13:00 MST 2015
Please open a command window and tyep the following commands
cscript
ipconfig/all
and post your output (as text)
lpcware
Content originally posted in LPCWare by aferrari on Wed Jul 29 08:44:02 MST 2015
ok done
C:\Documents and Settings\aferrari>SET
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\aferrari\Dati applicazioni
CLIENTNAME=Console
CommonProgramFiles=C:\Programmi\File comuni
COMPUTERNAME=LAB12
ComSpec=C:\WINDOWS\system32\cmd.exe
DAS_HOME=C:\Programmi\DAS\
EICDDrive=D:\
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\aferrari
LMC_HOME=C:\Xilinx\10.1\ISE\smartmodel\nt\installed_nt
LM_LICENSE_FILE=C:\Programmi\Metrowerks\CodeWarrior\license.dat
LOGONSERVER=\\LAB12
MW56800ELibraries=C:\Programmi\Metrowerks\CodeWarrior\M56800E Support
MW56800ELibraryFiles=Runtime 56800E.Lib;MSL C 56800E.lib
MW56800Libraries=C:\Programmi\Metrowerks\CodeWarrior\M56800 Support
MW56800LibraryFiles=FP56800.lib;MSL C 56800.Lib
MWAsm56800EIncludes=C:\Programmi\Metrowerks\CodeWarrior\M56800E Support
MWAsm56800Includes=C:\Programmi\Metrowerks\CodeWarrior\M56800 Support
MWC56800EIncludes=C:\Programmi\Metrowerks\CodeWarrior\M56800E Support
MWC56800Includes=C:\Programmi\Metrowerks\CodeWarrior\M56800 Support
NO_XILINX_DATA_LICENSE=HIDDEN
NUMBER_OF_PROCESSORS=4
OS=Windows_NT
Path=C:\Xilinx\10.1\ISE\bin\nt;C:\Xilinx\10.1\ISE\lib\nt;C:\Xilinx\10.1\ISE\smartmodel\nt\installed_nt\lib\pcnt.lib;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\Metrowerks\CodeWarrior\DSP56800x_EABI_Tools\Command_Line_Tools\;C:\Programmi\Flash Magic;c:\Programmi\Microsoft SQL
Server\100\Tools\Binn\;c:\Programmi\Microsoft SQL Server\100\DTS\Binn\;C:\WINDOWS\system32\;C:\Xilinx\10.1\ISE\bin\nt;C:\Xilinx\10.1\ISE\lib\nt;C:\Xilinx\10.1\ISE\smartmodel\nt\installed_nt\lib\pcnt.lib;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\Metrowerks\CodeWarrior\DSP5
6800x_EABI_Tools\Command_Line_Tools\;C:\Programmi\Flash Magic;c:\Programmi\Microsoft SQL Server\100\Tools\Binn\;c:\Programmi\Microsoft SQL Server\100\DTS\Binn\;C:\WINDOWS\system32\;C:\PROGRA~1\FLASHM~1
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 6 Model 42 Stepping 7, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=2a07
PROMPT=$P$G
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\aferrari\IMPOST~1\Temp
TMP=C:\DOCUME~1\aferrari\IMPOST~1\Temp
USERDOMAIN=LAB12
USERNAME=aferrari
USERPROFILE=C:\Documents and Settings\aferrari
VBOX_INSTALL_PATH=C:\Programmi\Oracle\VirtualBox\
VS100COMNTOOLS=C:\Programmi\Microsoft Visual Studio 10.0\Common7\Tools\
windir=C:\WINDOWS
XILINX=C:\Xilinx\10.1\ISE
XIL_PAR_OVERRIDE_CLKPH1_RULES=1
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Jul 29 08:37:18 MST 2015
And how am I meant to read that? Please copy the text and post it into the forum as text.
lpcware
Content originally posted in LPCWare by aferrari on Wed Jul 29 08:35:45 MST 2015
ok attached you'll find the output of SET command.
Let me know if it is enough.
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Jul 29 08:22:33 MST 2015
If you want me to help, please follow ALL of my instructions:
Quote:
If either of these files is present, please attach them. If not, what is your PATH? What else is in your environment (type SET in a command prompt)
lpcware
Content originally posted in LPCWare by aferrari on Wed Jul 29 08:15:37 MST 2015
I've checked and the path %ALLUSERSPROFILE% is C:\Documents and Settings\All Users, but in this directory there are neither LPCXpresso.sib nor LPCXpresso.acc files (see the attached picture).
What do you think about this?
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Jul 29 07:59:20 MST 2015
The 7.3.0 reference is only to the installer reporting the problem. The rest of the FAQ is applicable to all versions.
The error "No license to activate" means that "Create Serial Number and Activate" failed to create the local license file. See this FAQ for how to find the license directory:
https://www.lpcware.com/content/faq/lpcxpresso/where-license-stored
For a valid free license, there should be both LPCXpresso.sib and LPCXpresso.acc files.
lpcware
Content originally posted in LPCWare by aferrari on Wed Jul 29 07:27:53 MST 2015
Thanks for the hint.
I've added the variable but it didn't fix the problem.
Besides this, I'm using the LPCXpresso v. 7.0.2 (in order to use it on windows XP),  whilst your FAQ refers to LPCXpresso 7.3.0 and later.
Do you have any other idea?
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Jul 29 07:11:19 MST 2015
Suggest you read this FAQ:
https://www.lpcware.com/content/faq/lpcxpresso/windows-path-issues
