LPCXpresso Activation Failure
3,755件の閲覧回数
sarang
Actvation process for LPCXpresso V8.8.2 is not available.After generating serial number then the next page "https://lpcxpresso-activation.nxp.com/login_process.php " shows nothing.
3 返答(返信)
3,304件の閲覧回数
lpcxpresso_supp
I'm sorry for the problems you are encountering with activating your LPCXpresso IDE installation.
There have been issues with the https://lpcxpresso-activation.nxp.com site used for generating LPCXpresso IDE Free Edition activation codes recently. But these should have all been resolved as of yesterday. It is possible that it might take a few hours for DNS records to update around the internet for the new server that has been set up though.
It would be interesting to know if, when you attempt to go to the website, whether you are already logged into the main www.nxp.com website or not makes any difference?
And if you are not logged in on nxp.com, when you go to the activation site, do you get redirected to the login page or not?
Note: One other way forward here may be to consider using the newer MCUXpresso IDE product (which has superseded the older LPCXpresso IDE product). This does not require activation to function in Free Edition mode, so should avoid the problems you are currently encountering.
For more details and to download, please visit : http://www.nxp.com/mcuxpresso/ide
LPCXpresso Support
3,304件の閲覧回数
sarang
Thank you for your response. I tried both methods of activation process .when i tried without logged in its redirecting to login page(internal and external browser).And if i try activation site after logged in it shows the same blank page "https://lpcxpresso-activation.nxp.com/login_process.php". still it shows the same issue
3,304件の閲覧回数
lpcxpresso_supp
We are seeing other reports of continuing problems with the site. Please watch this thread for updates on status - Can not activate license
LPCXpresso Support
