LPC2362 examples?
LPC2362 examples?
lpcware
Content originally posted in LPCWare by MotoCon on Sun Dec 12 14:54:33 MST 2010
Looking here: http://ics.nxp.com/support/lpcxpresso/  I don't see any LPC23xx examples.  Are there any LPC23xx samples available using an interrupt?
lpcware
Content originally posted in LPCWare by CodeRedSupport on Tue Dec 14 01:26:11 MST 2010
There are no LPCXpresso example projects for LPC2362, but it should be fairly easy to port NXP's standard LPC23xx sample code bundle into LPCXpresso. You can find the LPC23xx/24xx sample bundle at:
http://ics.nxp.com/support/documents/microcontrollers/?search=LPC23&type=software
There are also a few notes on porting code into LPCXpresso that you might want to read at:
http://support.code-red-tech.com/CodeRedWiki/PortingCodeOtherToolchains
CodeRedSupport
