LPC1769 error reported
3,672 次查看
sebastianbarcia
I was debugging a project of lpc1769 with lpcxpresso and show me the follow code error. Is the microcontroller dead?
How can i fix it?
3,403 次查看
lpcxpresso_supp
Have you ever been able to debug your system? If so what changed, or what code did you program into the MCU, before it stopped working?
Is this an off-the-shelf board, or your own board?
If your own board, please check out - https://community.nxp.com/message/630601
What debug probe are you using?
What version of LPCXpresso IDE are you using? And on what host OS ?
Please also double check that you following the process for booting the chip into ISP mode correctly - you must be pulling the ISP pin as the board is reset/powered up.
LPCXpresso Support
3,403 次查看
lpcxpresso_supp
In the first place, see :https://community.nxp.com/message/630748
LPCXpresso Support
3,403 次查看
sebastianbarcia
Thanks for your reply
None of that worked
I can not erase the flash
Mode ISP not response
