LPC1768 PWM, bringing pin low
701 次查看
lpcware
Content originally posted in LPCWare by richas on Fri Aug 23 11:33:08 MST 2013
   I am using PWM on the LPC1768.  I wish to be able to turn off the PWM at a pin, bringing the pin low.  I have tried the PCR register but it appears to leave the pin in whatever state it currently is.
What is the cleanest way to shut off to a pin, leaving the pin low?
rich
1 回复
663 次查看
lpcware
Content originally posted in LPCWare by richas on Fri Aug 23 11:55:57 MST 2013
I have it working using the PINSEL reg, not sure if there is a cleaner way.........
Rich
