LPC11Cxx CAN-BUS Help
lpcware
Content originally posted in LPCWare by LexaryStyle on Sat Apr 16 13:09:13 MST 2011
Hi All.
I was read LPC111x/[B]LPC11Cxx[/B] User manual UM10398 and i can't find [B]CAN speed(100,250,500,1M) \ CAN bit timing register[/B] table, how can get it for us?
And i find error in Table 209, see row "Description", please check it.
Thanks.
lpcware
Content originally posted in LPCWare by NXP_Europe on Tue Apr 19 14:47:42 MST 2011
Hello LexaryStyle,
Quote:
0010: CAN_CLK = PCLK divided by 3
0010: CAN_CLK = PCLK divided by 4.
is type-error ... will be changed. Should be
0011: CAN_CLK = PCLK divided by 4.
Thanks.
lpcware
Content originally posted in LPCWare by Ex-Zero on Mon Apr 18 14:32:46 MST 2011
Would suggest to use 48MHz:
100k: 0x127
200k: 0x113
250k: 0x10F
500k: 0x107
1000k: 0x103
lpcware
Content originally posted in LPCWare by larryvc on Mon Apr 18 14:24:23 MST 2011
Very good guess.  I'm not seeing that well today,  too much fun yesterday.
Danke
lpcware
Content originally posted in LPCWare by Ex-Zero on Mon Apr 18 14:15:24 MST 2011
Guess:
lpcware
Content originally posted in LPCWare by larryvc on Mon Apr 18 14:11:53 MST 2011
Please describe the error you found in more detail.
lpcware
Content originally posted in LPCWare by Ex-Zero on Mon Apr 18 13:49:29 MST 2011
Wrong question :mad:
What CAN_CLK are you using?
lpcware
Content originally posted in LPCWare by LexaryStyle on Mon Apr 18 13:27:26 MST 2011
Yes, what write in [COLOR=Red]CANBT[COLOR=black] if use 12Mhz oscillator for:
100Kbps
200kbps
250kbps
500kbps
and 1000kbps
[/COLOR][/COLOR]
lpcware
Content originally posted in LPCWare by Ex-Zero on Sat Apr 16 13:17:54 MST 2011
Quote: LexaryStyle
Hi All.
Thanks.
What about[COLOR=Red] CANBT[/COLOR]?
