LPC11C24 LPCXpresso Board stopped functioning
1,325 次查看
Content originally posted in LPCWare by lab1 on Tue Apr 01 03:41:53 MST 2014
I worked with my development board (LPC11C24 LPCXpresso Board) and suddenly it stopped working.
I've made some measurements on the development board between pins 54 and 28, and I only measure 0.67V is there anyone who knows what might be wrong?
6 回复数
1,300 次查看
Content originally posted in LPCWare by LabRat on Tue Apr 01 06:04:35 MST 2014
Quote: lab1
I make some measurements, and I get 5V on one side of D2 and 0.59 V on the other side of the diode.
And do you think 5V-0.59V = 4.41V is the correct VF for a Schottky??
http://www.nxp.com/documents/data_sheet/PMEGXX05EH_EJ_SER.pdf
1,300 次查看
Content originally posted in LPCWare by lpcxpresso-support on Tue Apr 01 06:02:38 MST 2014
Please explain what has "stopped working". Measuring voltages is not very helpful when we don't even know what the problem is.
1,300 次查看
Content originally posted in LPCWare by lab1 on Tue Apr 01 05:54:15 MST 2014
1,300 次查看
Content originally posted in LPCWare by LabRat on Tue Apr 01 05:11:17 MST 2014
Could be useful to:
- check D1-D3
- supply your target with 3.3V (J6-28)
- supply LPCXpresso with 5V at VIN (J6-2)
1,300 次查看
Content originally posted in LPCWare by lab1 on Tue Apr 01 04:53:04 MST 2014
No. I'm talking about J6-28 and J6-54 LPCXpressoLPC11C24revB page 6
I decided also to measure Power Supply Party of LPC3154 page 2, and I have measured 0V R1, 0.59V R2 and 0V R3.
Does anyone have an explanation for this?
The error occurred right after I had started a debugging of a new project.
1,300 次查看
Content originally posted in LPCWare by LabRat on Tue Apr 01 04:03:35 MST 2014
Quote: lab1
...between pins 54 and 28, and I only measure 0.67V is there anyone who knows what might be wrong?
Are we talking about J6?
If so, LPC11C24 isn't working with 0.67V  :)
