LPC11A14 - Have default EEPROM values
737件の閲覧回数
lpcware
Content originally posted in LPCWare by tyassin on Fri Sep 06 04:22:29 MST 2013
Is it possible to make/load default values into the EEPROM when it is programmed?
So these will be used when running.
718件の閲覧回数
lpcware
Content originally posted in LPCWare by tha on Fri Sep 06 11:14:01 MST 2013
No, that won't be possible.  The only way to access the EEPROM is through IAP calls during run time.  During programming time, there is no way to access the EEPROM
