LPC1114FN28 problem
LPC1114FN28 problem
1,521件の閲覧回数
lpcware
Content originally posted in LPCWare by Gastonio on Sat Nov 10 09:32:49 MST 2012
Hello, I am having problem programming LPC1114FN28 MCU. For this, I am using LPCXpresso LPC1769 board, disconected target side.  The LPCXpresso shows, that program was downloaded, however - nothing happens, port is still high, when the program was to make it low.
[SIZE=2][/SIZE]
[SIZE=2][SIZE=2]LPC_GPIO0->[COLOR=#0000c0]DIR[/COLOR][SIZE=2]|=(1<<7);[/SIZE]
[/SIZE][SIZE=2]
LPC_GPIO0->[COLOR=#0000c0]DATA[/COLOR][SIZE=2]&=~(1<<7);[/SIZE][SIZE=2][/SIZE]
[SIZE=2][/SIZE][/SIZE]
5 返答(返信)
1,505件の閲覧回数
lpcware
Content originally posted in LPCWare by Gastonio on Sat Nov 10 15:15:05 MST 2012
Quote: Gastonio
Yeah, I know, however I can't do steps or switch ports using Peripherals View.
The problem was in selecting the clock source, the default was external clock source. Now I am able to debug. Guess it's a good reason to drink a beer for that after all, thanks anyway.
1,505件の閲覧回数
lpcware
Content originally posted in LPCWare by Gastonio on Sat Nov 10 11:59:09 MST 2012
Quote: Zero
:confused:
Do you know what a debugger is :confused:
So is it running? Stepping? Drinking a beer?
What's it's Perihherals view telling you about your GPIO?
What's it's Perihherals view telling you about your IOCON?
Did you try to switch your GPIO via Peripherals View?
1,505件の閲覧回数
lpcware
Content originally posted in LPCWare by Ex-Zero on Sat Nov 10 11:48:24 MST 2012
Quote: Gastonio
...however nothing happens.
:confused:
1,505件の閲覧回数
lpcware
Content originally posted in LPCWare by Gastonio on Sat Nov 10 11:21:08 MST 2012
Quote: Zero
Congratulation, now start your debugger :)
Thanks for the reply. I did start debugger when downloading the program, however nothing happens.
1,505件の閲覧回数
lpcware
Content originally posted in LPCWare by Ex-Zero on Sat Nov 10 09:54:03 MST 2012
Quote: Gastonio
The LPCXpresso shows, that program was downloaded...
