LPC board revision not recognized
lpcware
Content originally posted in LPCWare by ardbiesheuvel on Tue Jan 04 07:27:30 MST 2011
Never mind, should have read the FAQ...
lpcware
Content originally posted in LPCWare by CodeRedSupport on Tue Jan 04 07:33:03 MST 2011
If you are connecting to an LPC1769, you need to select LPC1769 as the target. See:
http://support.code-red-tech.com/CodeRedWiki/ChangingProjectTarget
