LPC-Link + another IDE
944件の閲覧回数
lpcware
Content originally posted in LPCWare by Lean966 on Fri Oct 01 12:08:29 MST 2010
I have the LPC-Link w/ LPCxpresso. I want to know if I can use the LPC-Link with another IDE like Keil, CodeSourcery, etc. Thank you. Leandro
3 返答(返信)
938件の閲覧回数
lpcware
Content originally posted in LPCWare by cfb on Sat Oct 02 15:28:09 MST 2010
Contact Code Sourcery for support at:
http://www.codesourcery.com/support
938件の閲覧回数
lpcware
Content originally posted in LPCWare by Lean966 on Fri Oct 01 15:22:45 MST 2010
Thank you, Renan. I'm trying to use GNU and Sourcery G++ and LPC1764 with CMSIS, it's a headache :). I have problem with the linker (.ld) and the __cs3_ variables (like __cs3_ interrupt_vector_cortex_m). I don't know where I should initialize it. Could you help me? Thank you again.
938件の閲覧回数
lpcware
Content originally posted in LPCWare by renan on Fri Oct 01 12:12:12 MST 2010
As far as I know, you can't.
Renan
