I2cSlave problem on lpc1343
449件の閲覧回数
Content originally posted in LPCWare by laplans on Mon May 13 07:58:20 MST 2013
I'm trying to use the lpc1343 as a i2cslave to transmit some data. Writing to the board gives no problems and works exactly as I want it.
However, reading from the board gives problems. It seems I'm not getting any data back although I am sending the right commands. Whenever I try to debug it my board just hangs and I have to reset the driver and my pc to get it running again.
Also, I made a LED go on/off whenever I try to read from it. It only does this once and whenever I try to do it again nothing happens. I think the I2c is stopped then but I have no idea why.
I have found the example code on the website once but now it seems to be gone. Does somebody have an updated I2cslave code?
Thanks for the help!
0 返答(返信)
