I have Windows 2000
I have Windows 2000
788 次查看
lpcware
Content originally posted in LPCWare by Maru_t on Wed May 12 18:50:39 MST 2010
I have a PC  with Windows 2000 (5.00.2195 Service Pack 4).
In the document of "Getting started with NXP LPCXpresso", at the section of "3.Installation/3.1System requirements", "Operating System" doesn't include "Windows 2000".
Does it means that I must change OS in my PC at once?
Are there anything what could I do with the LPCXpresso Board(Target LPC1114) in my working environment, now?.
I'd like to check anything possible about this board on my PC.
Thank you any help, or suggestions!
M_t
782 次查看
lpcware
Content originally posted in LPCWare by Maru_t on Thu May 13 00:26:37 MST 2010
Thank you!
I will do fulfill minimum requirements on the PC for LPC1114.:cool:
M_t
782 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Wed May 12 23:49:03 MST 2010
I'm sorry, but you will not be able to install or run the software on Windows2000. The minimum requirement is as specified in the Getting Started guide.
