How to disable watchdog?
2,780 次查看
lpcware
Content originally posted in LPCWare by 12345 on Wed Jul 06 23:27:03 MST 2011
How can I disable watchdog after I enable it and its reset?
       Manual mentioned there is no software disable.
       Tks.
6 回复数
2,602 次查看
lpcware
Content originally posted in LPCWare by Terje on Wed Jan 22 09:11:50 MST 2014
12345,
Did you find a solution to this? I have the same question.
2,602 次查看
lpcware
Content originally posted in LPCWare by 12345 on Fri Jul 08 00:49:19 MST 2011
Once the WDEN and/or WDRESET bits are set, they can not be cleared by software. Both
flags are cleared by a reset or a Watchdog timer underflow.
2,602 次查看
lpcware
Content originally posted in LPCWare by 12345 on Thu Jul 07 20:28:46 MST 2011
Quote: OXO
http://ics.nxp.com/support/documents/microcontrollers/pdf/user.manual.lpc11xx.lpc11cxx.pdf
p278 WDMOD register?
2,602 次查看
lpcware
Content originally posted in LPCWare by OXO on Thu Jul 07 02:07:20 MST 2011
2,602 次查看
lpcware
Content originally posted in LPCWare by 12345 on Wed Jul 06 23:34:47 MST 2011
Quote: Serge
And we are talking about which MCU?
  lpc1114-302
2,602 次查看
lpcware
Content originally posted in LPCWare by serge on Wed Jul 06 23:30:41 MST 2011
