How to build Project have *.o file
790件の閲覧回数
lpcware
Content originally posted in LPCWare by ethan_kao on Fri Apr 25 02:47:46 MST 2014
I have "abc.c" "abc.h" file
function "void Test(void)" define in "abc.h" and coding in "abc.c"
I have a main.c call  "void Test(void)"
first build has create new file "abc.o"
Can I remove "abc.c" and move abc.o in my project
function void Test(void) is my Algorithms ,I do not want others to see content
Thanks you
781件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Apr 25 03:06:18 MST 2014
You probably want to use a library project:
http://www.lpcware.com/content/faq/lpcxpresso/creating-linking-library-projects
