How do I populate crt_directory.xml
lpcware
Content originally posted in LPCWare by zl1jk on Thu Feb 17 13:56:45 MST 2011
Hi All,
I get the following when I attempt to flash the LPC1114/301 board I have.:
02: Failed on connect: Ee(04). Invalid emulator index - get list of available emulators.
31: No connection to emulator device
My C:/nxp/lpcxpresso_3.6/bin/crt_directory.xml file is empty.
I am running XP SP3
lpcware
Content originally posted in LPCWare by zl1jk on Thu Feb 17 14:22:23 MST 2011
Ignore this.
This error occurs when you do not select a device. Even though it is already connected.
