Hover display
Hover display
930 次查看
lpcware
Content originally posted in LPCWare by mayotte1 on Thu Apr 08 15:14:22 MST 2010
In the debugger when you hover over a variable it displays the value. Is there some way to change the format to hexadecimal instead of decimal?
2 回复数
918 次查看
lpcware
Content originally posted in LPCWare by leon_heller on Fri Apr 09 03:37:41 MST 2010
It's a deficiency in Eclipse, it's the same with another development system I have which uses it. I use another IDE a lot for ARM and MSP430 development (CodeRed should know which one I mean) and that displays variable values in decimal, hex, binary and ASCII when the cursor hovers over them.
918 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Fri Apr 09 00:32:31 MST 2010
Sorry, this is not possible.
