Hover display
Hover display
914件の閲覧回数
Content originally posted in LPCWare by mayotte1 on Thu Apr 08 15:14:22 MST 2010
In the debugger when you hover over a variable it displays the value. Is there some way to change the format to hexadecimal instead of decimal?
902件の閲覧回数
Content originally posted in LPCWare by leon_heller on Fri Apr 09 03:37:41 MST 2010
It's a deficiency in Eclipse, it's the same with another development system I have which uses it. I use another IDE a lot for ARM and MSP430 development (CodeRed should know which one I mean) and that displays variable values in decimal, hex, binary and ASCII when the cursor hovers over them.
902件の閲覧回数
Content originally posted in LPCWare by CodeRedSupport on Fri Apr 09 00:32:31 MST 2010
Sorry, this is not possible.
