Host Strings Builder error on clean build
lpcware
Content originally posted in LPCWare by mhjerde on Tue Sep 18 23:46:45 MST 2012
I get this error when doing a clean build:
'Clean Project' has encountered a problem.
Problems occurred building the selected resources.
Errors running builder 'Host Strings Builder' on project 'KickV2b'.
Resource '/KickV2b/hoststrings.xml' does not exist.
Im using Red Suite 4 (NXP edition)
Any ideas?
lpcware
Content originally posted in LPCWare by mhjerde on Wed Sep 19 00:58:16 MST 2012
Thanks!
I added an empty hoststrings.xml file and the problem went away.
M
I should probably check it out more as it looks like hoststrings may be a nifty feature :-)
lpcware
Content originally posted in LPCWare by whitecoe on Wed Sep 19 00:27:30 MST 2012
Hoststrings functionality (which AFAIK is part of Red Trace) isn't in LPCXPresso IDE. Thus you are probably going to need to contact Code Red support directly for help on this, as I doubt that many people here have any experience of it.
HTH!
