Help! Cannot run any samples. Debugger stops with SIGSTOP.
lpcware
Content originally posted in LPCWare by akozlov on Mon Apr 05 11:06:30 MST 2010
Hello
Can anyone help with the problem?
When attempt to run the application (including samples) the debugger stops with SIGSTOP. All memory appears to contain 0x60d32300 (as viewed in memory view).
When attempt to step over disassemble view, I see memory content disappear  (replaced with 0x60d32300) after few steps.
lpcware
Content originally posted in LPCWare by CodeRedSupport on Mon Apr 05 23:43:13 MST 2010
I'm sorry but you have not provided enough information to be able to help. Can you please state exactly what you are doing to reproduce the error. Please also state which hardware you are using, and details on your host OS.
