Header file is required or not??
1,164件の閲覧回数
lpcware
Content originally posted in LPCWare by Prajakta_26 on Tue Jan 26 23:30:26 MST 2016
I have just installed LPCXpresso_7.9.0_455 on windows 8.
I want to use this with LPC2138. whether I required "LPC213x.h" file?
If yes please tell me how can I get it?
If No any header required , Can I access the registers of LPC2138 & how ?
2 返答(返信)
1,148件の閲覧回数
lpcware
Content originally posted in LPCWare by Prajakta_26 on Wed Jan 27 01:54:51 MST 2016
Thanks for example code.
If I don't use "LPC213x.h"  file, then can I access LPC2138 registers ? & how?
1,148件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Jan 27 01:26:00 MST 2016
You can use it if you want too. A version is supplied in the LPCXpresso Examples directory within your installation ...
[install_dir]\lpcxpresso\Examples\Legacy\LPCXpresso_old_headers.zip
Just import that ZIP into your workspace,
But you probably want to take a look at the sample code bundle :
https://www.lpcware.com/content/nxpfile/sample-code-bundle-lpc213xlpc214x-peripherals-using-keils-μv...
Hints and tips on porting code from the Keil compiler to GCC used in LPCXpresso IDE can be found in :
https://www.lpcware.com/content/faq/lpcxpresso/porting-code-other-toolchains
LPCXpresso Support
