HOW TO get Code coverage
lpcware
Content originally posted in LPCWare by [email protected] on Tue Nov 19 08:57:58 MST 2013
Is there a suitable code coverage tool that works with a bare-metal implementation?
OR if that is not possible, is it possible at the very least to extract from the IDE the profiling/sampling coverage data to a file, and do so automatically in a 'headless' way from the command line?
Basically I want to run unit tests, and then collect together all the code coverage details.
Any help is appreciated!
