HAL in LPCXpresso
HAL in LPCXpresso
1,106 次查看
lpcware
Content originally posted in LPCWare by masterboy on Sat Mar 09 11:17:28 MST 2013
Hi all,
I would like to ask you. Is there any library that contains functions for example SystemInit() and for peripherals? I mean that it calls "HAL" but I don't know what library is it ... :(
2 回复数
1,082 次查看
lpcware
Content originally posted in LPCWare by graynomad on Sun Mar 10 08:54:22 MST 2013
All the samples I've been able to find have not really been a HAL, CMSIS helps but it also is no HAL.
So I made a start on a HAL for the 1227, it's not even close to being finished but what I've done works pretty well. You can get the idea here
http://lard.robgray.com/index.php
Unfortunately I've got a largish project on the go right now but I plan to get back to this soon.
1,082 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun Mar 10 03:52:15 MST 2013
Typically within the CMSIS library project within the Examples subdirectory on your LPCXpresso IDE installation.
More info...
http://support.code-red-tech.com/CodeRedWiki/SuppliedExamples
http://support.code-red-tech.com/CodeRedWiki/Support4CMSIS
CodeRedSupport
