Content originally posted in LPCWare by ArneB on Fri Jul 29 02:37:21 MST 2011
In my next project I have to isolate the serial wire debug interface of my LPC1114, because I power my board from a different power domain than my LPC Link.
My problem is the bidirectional SWD line. I have found so far only isolators designed for I2C with a bidirectional port (e.g. ADUM1250), but they are too slow (max. 1 MHz). As far as i understood, the debug port uses higher clock frequencies (4..8 MHz ?)
Does anyone have any recommendations or maybe already schematics how to do it ?
Thank you for your help :)
