From CodeRed5NXP edition to LPCXPRESSO 6
1,025 次查看
lpcware
Content originally posted in LPCWare by blasiis on Mon Jan 05 04:21:42 MST 2015
Dear all, I have change my PC and now must reinstall all.
In my old pc was installed Red Suite 5 NXP Edition (256k) with activation code purchased.
Now, codered id ded and what should I Install ? How can use my license ?
Stefano
1,018 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Jan 05 04:36:52 MST 2015
I would recommend that you simply move to LPCXpresso 7.5, as suggested by R2D2. Further information and downloads of LPCXpresso 7 can be found at:
http://www.lpcware.com/lpcxpresso
Moving an existing Red Suite 5 project across to LPCXpresso 7 should not be a problem, though I would advise you to read the notes at:
http://www.lpcware.com/content/faq/lpcxpresso/migrating-existing-projects
However if you do wish to continue using your Red Suite 5, as long as you have your activation code to hand, you should be able to simply install and activate that too:
http://support.code-red-tech.com/CodeRedWiki/MovingLicenses
LPCXpresso Support
1,018 次查看
lpcware
Content originally posted in LPCWare by R2D2 on Mon Jan 05 04:26:29 MST 2015
Just use LPCXpresso 7.5 with 256k debug limit  :quest:
