Flash in production
Flash in production
612 次查看
lpcware
Content originally posted in LPCWare by maxmel on Mon Sep 19 08:07:23 MST 2011
I m looking for a tool to flash a file  in .HEX format for the production
i know there is segger
but with lpcXpresso is it possible to flash a .hex
if yes what is the procedure ?
Thank u
1 回复
605 次查看
lpcware
Content originally posted in LPCWare by Luis Digital on Mon Sep 19 13:27:45 MST 2011
[B]Using the command line flash programming tool[/B]
Personally I think you should use ISP for production.
