FT/GPIO and MSD
FT/GPIO and MSD
Content originally posted in LPCWare by bobi-one on Mon Mar 28 07:02:23 MST 2011
I am trying the mass storage example ,and as far as I understand, to enumerate the board FT/GPIO must be LOW, and after  I copy the bin file the only way my code to run is to release FT/GPIO, so is it possible , not to need  toggling  FT/GPIO for transfer and running  the code. Do I need hardware/software modification
Sry if the post doubles, because the topic was discussed hundred times, but i just cant find a solution.
