Eclipse preferences
Eclipse preferences
952件の閲覧回数
lpcware
Content originally posted in LPCWare by Birdie11 on Sat Apr 30 15:09:10 MST 2011
I have some beginner questions:
1.) How can I save all ide settings for restoring on a different computer?
2.) Is there no separate indent setting besides the TAB setting?
3.) Why I cannot assign a shortkey for setting breakpoints?
4.) No "find in project files" or "grep" or similar?
2 返答(返信)
943件の閲覧回数
lpcware
Content originally posted in LPCWare by Birdie11 on Sun May 01 11:52:25 MST 2011
Thank you - solved almost everything except the toggle breakpoint issue. Have no idea why my assignment is not working, but is not important.
943件の閲覧回数
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun May 01 08:15:56 MST 2011
[FONT=Courier New][SIZE=1]File > Export > General > Preferences[/SIZE][/FONT] will allow you to share settings such as your customised keyboard shortcuts,  formatting, repository settings, etc.
Then use [FONT=Courier New][SIZE=1]File > Import > General > Preferences[/SIZE][/FONT] to pull into your other computer/workspace.
You can insert spaces for tabs, if that is what you mean. See:
http://support.code-red-tech.com/CodeRedWiki/EditorHints
[SIZE=1][B][FONT=Courier New]Ctrl-Shift-B [/FONT][/B][/SIZE]?
For more, and to potentially changes shortcuts, take a look at:
[B][FONT=Courier New][SIZE=1]Menu->Window->Preferences->General->Keys[/SIZE][/FONT][/B]
Have you tried using the "Search" option on the main menu bar?
CodeRedSupport
