EMAC does not work
EMAC does not work
529件の閲覧回数
lpcware
Content originally posted in LPCWare by tom84 on Tue Mar 20 01:47:23 MST 2012
I downloaded the "mcb1700.code.bundle.lpc1769.lpcxpresso" for testing the ethernet interface.
Because i use an LPC1758, i changed the MCU settings and in "tcpip.h" i changed the Ip-Adresses. I am pretty sure that there no misstake.
But when i try to ping the board, the answer is "Host unreachable", what could be the problem? I removed Jumper on ISP and RST! and the 3 jumpers E/C, E/U are like in the picture on page 7 of the "code.bundle.lpc17xx.keil.emac.pdf".
I tried the easyweb programm for uvision and it worked fine, no matter how the jumper were set....
0 返答(返信)
