Download LPCXpresso v4.3.0 does not work
lpcware
Content originally posted in LPCWare by Mirjan Hajnc on Fri Dec 06 06:11:02 MST 2013
I wanted to download previous version (LPCXpresso v4.3.0) of LPCExpresso from http://www.lpcware.com/lpcxpresso/downloads/older , but download does not work correctly.
I would like to ask you if you could fix download site for previous versions.
Br,
Mirjan.
lpcware
Content originally posted in LPCWare by Mirjan Hajnc on Fri Dec 06 08:08:14 MST 2013
Yes It works.
Thank you very much.
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Dec 06 07:30:11 MST 2013
Quote: lpcxpresso-support
Looks like there is a permissions issue on the server hosting the 4.30 installers. We are investigating.
LPCXpresso Support
Should now be fixed.
lpcware
Content originally posted in LPCWare by TheFallGuy on Fri Dec 06 07:29:45 MST 2013
It looks like you can download again now - it is working for me.
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Dec 06 06:43:18 MST 2013
LPCXpresso Support
lpcware
Content originally posted in LPCWare by Mirjan Hajnc on Fri Dec 06 06:26:15 MST 2013
I try now, but the Code-Red page redirect me to the "LPCware" page and there I get this message "LPCXpresso website has moved".
lpcware
Content originally posted in LPCWare by R2D2 on Fri Dec 06 06:17:55 MST 2013
Did you try good old Code-Red download?
http://support.code-red-tech.com/CodeRedWiki/VersionInfo
