Download LPCXpresso v4.3.0 does not work
1,318 次查看
Content originally posted in LPCWare by Mirjan Hajnc on Fri Dec 06 06:11:02 MST 2013
I wanted to download previous version (LPCXpresso v4.3.0) of LPCExpresso from http://www.lpcware.com/lpcxpresso/downloads/older , but download does not work correctly.
I would like to ask you if you could fix download site for previous versions.
Br,
Mirjan.
6 回复数
1,258 次查看
Content originally posted in LPCWare by Mirjan Hajnc on Fri Dec 06 08:08:14 MST 2013
Yes It works.
Thank you very much.
1,258 次查看
Content originally posted in LPCWare by lpcxpresso-support on Fri Dec 06 07:30:11 MST 2013
Quote: lpcxpresso-support
Looks like there is a permissions issue on the server hosting the 4.30 installers. We are investigating.
LPCXpresso Support
Should now be fixed.
1,258 次查看
Content originally posted in LPCWare by TheFallGuy on Fri Dec 06 07:29:45 MST 2013
It looks like you can download again now - it is working for me.
1,258 次查看
Content originally posted in LPCWare by lpcxpresso-support on Fri Dec 06 06:43:18 MST 2013
LPCXpresso Support
1,258 次查看
Content originally posted in LPCWare by Mirjan Hajnc on Fri Dec 06 06:26:15 MST 2013
I try now, but the Code-Red page redirect me to the "LPCware" page and there I get this message "LPCXpresso website has moved".
1,258 次查看
Content originally posted in LPCWare by R2D2 on Fri Dec 06 06:17:55 MST 2013
Did you try good old Code-Red download?
http://support.code-red-tech.com/CodeRedWiki/VersionInfo
