Disassembly
Disassembly
lpcware
Content originally posted in LPCWare by Prajakta_26 on Mon Aug 24 22:36:33 MST 2015
I am using LPCXpresso IDE & red probe debugger from last 6 months. Up to now I have programmed many cards using same IDE & debugger. but now, When I am doing programming at the end, it shows "view dis-assembly". Please help me in this.
lpcware
Content originally posted in LPCWare by Prajakta_26 on Thu Aug 27 21:08:11 MST 2015
Before going ahead, I would like to ask, whether the wrong/ incorrect values in MAM & PLL resistors kills/damage the micro-controller physically ? Coz when I found the error in programming the flash, at the same time micro-controller gets heated & regulator also, as the micro-controller drawing more current (near about 130mA) where  this current was near about 16mA before.
Ans to your ques : I tried to program it through ISP using flash magic. but since the micro-controller gets heated , ISP also not successful. The error is of auto baud.
I don't have debug log right now. I didn't save it. I will post it soon.
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Thu Aug 27 05:50:35 MST 2015
Quote: Prajakta_26
version of LPCXpresso IDE : V6.0.4
OS : windows XP
That's a very old version of LPCXpresso, though the latest ones no longer will run on WinXP.
Quote:
Recent changes I have been made in PLL & MAM resistors.
And you have double checked these changes? These are very likely to break things if you have got them wrong.
Anyway, you haven't posted your debug log, or confirmed if you have tried booting the board into ISP mode.
LPCXpresso Support
lpcware
Content originally posted in LPCWare by Prajakta_26 on Thu Aug 27 03:05:32 MST 2015
Here are the details ;
OS : windows XP
Debug probe : Red probe+
MCU : LPC2138
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Tue Aug 25 03:13:44 MST 2015
What version of LPCXpresso IDE are you running?
What host OS are you running on?
What debug probe are you using?
What target board and MCU are you using?
What does the debug log show after starting a debug session?
[list]
  [*]https://www.lpcware.com/content/faq/lpcxpresso/debug-log
[/list]
Does booting your board into ISP mode before starting a debug session help?
[list]
  [*]https://www.lpcware.com/content/faq/lpcxpresso/regaining-debug-access
[/list]
And if this has been working for 6 months, what recent changes have been made in your setup?
LPCXpresso Support
lpcware
Content originally posted in LPCWare by R2D2 on Mon Aug 24 22:53:24 MST 2015
Quote: Prajakta_26
...it shows "view dis-assembly". Please help me in this.
:quest:
Then view disassembly and describe your problem...
