Description and usage of lpcxpresso example projects
382 次查看
Content originally posted in LPCWare by MrTinkerTrain on Tue May 17 21:48:09 MST 2011
Am I missing something? Where is ther any documentation as to the usage of the various example projects? For instance lpc1343 uart? I build it but there is no explaination as to how it works. Like does it work with vitual comm port or do I need to provide real RS232 to it. Right now I'm running it in the Code Red Eclipse IDE. I go to Tera Term to connect to it and it only shows the std serial ports I have installed on my machine. :confused:
0 回复数
