DSC In-Application Programming
1,460 次查看
renanjohncañas
I would like to know if there any example codes or Application notes implementing In-application programming for DSC (e.g. MC56f82748). I already have a bootloader program but I want my application to be able to jump to the bootloader when it is flashed.
Are there proper routines to be performed first before executing a jump command to the bootloader _Entrypoint?
0 回复数
