Connection error Em(05)
lpcware
Content originally posted in LPCWare by jankup on Thu Nov 24 01:23:03 MST 2011
Hi all. I have one piece of LPC11c24 xpresso board. Yesterday I was trying to change clock source setup for using IRC oscilator. Maybe I made a mistake, so after last program cycle the board stop work and I cannot connect to it. If I want to debug new program I will get error:
02: Failed on connect: Em(05). Cannot find emulator speed that works.:
Does somebody know this error? Is there any way how can I repair it? Is there any way how can I erase chip memory in this state?
Thanks a lot for all answers.
Peter
lpcware
Content originally posted in LPCWare by jankup on Thu Nov 24 02:18:41 MST 2011
Thanks a lot for your reply. IT WORKS!! I was looking for solution two days and cant find anything. But it is soo easy. Thanks again.....
Quote: Zero
Switch to ISP as described in:
http://support.code-red-tech.com/CodeRedWiki/DebugAccessChip
lpcware
Content originally posted in LPCWare by Ex-Zero on Thu Nov 24 01:51:47 MST 2011
