Communication between Master Microcontroller to Slave Microcontroller
lpcware
Content originally posted in LPCWare by mahalinr on Mon Jun 02 04:45:45 MST 2014
Hallo
                I am currently using two LPC11C24 Microcontrollers where I need to send a message through CAN Protocol form one microcontroller to another microcontroller .
I kindly need your help
thanks in advance
lpcware
Content originally posted in LPCWare by mahalinr on Tue Jul 22 13:05:55 MST 2014
Hallo
Can you tell me how to connect Master microcontroller and slave microcontroller through CAN Communication
lpcware
Content originally posted in LPCWare by R2D2 on Fri Jun 06 07:36:17 MST 2014
:quest:
Sorry, I've no idea what you are doing...
As described in AN you need a Terminal program to get UART from Master connected...
lpcware
Content originally posted in LPCWare by mahalinr on Fri Jun 06 07:06:30 MST 2014
Thanks for your reply.
From the above program,I want to communicate te messages through Flash Magic.
I need to know hw to communicate a message from Slave node to Master node in Flash Magic.
When I try to run Slave node in Flash Magic,I am gettin an Blank screen.
So plz help me out in this
lpcware
Content originally posted in LPCWare by R2D2 on Mon Jun 02 04:52:44 MST 2014
Try AN11238:
http://www.lpcware.com/content/nxpfile/an11238-lpc11cxx-canopen-network-demo-0
