Comment Block of Selected Code
4,093 次查看
Content originally posted in LPCWare by rtos on Fri Jul 09 18:54:02 MST 2010
In LPCExpresso, is there a way to comment a block of selected code?
6 回复数
3,809 次查看
Content originally posted in LPCWare by domen on Sun Jul 11 23:54:14 MST 2010
Also... you could use the preprocessor:
#if 0
  commented code
#endif
3,809 次查看
Content originally posted in LPCWare by KaraMuraT on Sat Jul 10 07:39:00 MST 2010
A little note:
If you want to write MISRA-C compatible code, you must not use "//" style line comments. You have to use "/* */" style.
This really causes a slowdown in development process at the time making some code practices, but saves you from forgetting some necessary codes line commented, for the release version.
3,809 次查看
Content originally posted in LPCWare by rtos on Sat Jul 10 07:27:00 MST 2010
Quote: KaraMuraT
Select the source code you want to comment,
Right click,
Select "Source\Comment/Uncomment"
I think this is what you want.
P.S: The shortcut key is "Ctrl+/"
This is exactly what I'm looking for.  Thanks!
3,809 次查看
Content originally posted in LPCWare by KaraMuraT on Sat Jul 10 06:28:14 MST 2010
Right click,
3,809 次查看
Content originally posted in LPCWare by rtos on Sat Jul 10 05:54:14 MST 2010
sojiro, thanks.  I'm aware of this method.  However this method does not work if you have one line comments (//) embedded in the block you want to comment.  Many other IDEs have a command that will automatically put the // comment indicator in front of all the lines that you have selected (and remove it).  That is what I'm looking for.
3,809 次查看
Content originally posted in LPCWare by sojiro on Sat Jul 10 05:44:52 MST 2010
//for commenting one line
for commenting
blocks
