Command-line programming/flash of target
956件の閲覧回数
lpcware
Content originally posted in LPCWare by mfc on Mon Jan 10 02:26:19 MST 2011
Hi, I am planning to work with both mbed and LPCXpresso (176x), and I would like to try and keep my (non-IDE) toolchain as close as possible to be the same for both. It looks as though the compiler side will be identical, but I have not yet discovered how best to flash the ROM (program memory) -- essentially from command line (although in practice it would be invoked from a script).
It looks as though 'dfuapp' is the key to this, but I not been able to find any documentation. Any ideas?
Many thanks -- Mike Cowlishaw
2 返答(返信)
937件の閲覧回数
lpcware
Content originally posted in LPCWare by mfc on Mon Jan 10 03:02:42 MST 2011
Quote: CodeRedSupport
See http://support.code-red-tech.com/CodeRedWiki/CommandLineFlashProgramming
CodeRedSupport
Perfect.  Thanks!
937件の閲覧回数
lpcware
Content originally posted in LPCWare by CodeRedSupport on Mon Jan 10 02:38:58 MST 2011
CodeRedSupport
