Command line build
Command line build
1,368件の閲覧回数
lpcware
Content originally posted in LPCWare by simonk on Tue Apr 08 07:34:32 MST 2014
Hello all,
I would like to introduce a build server in my team. So I would like to have a simple command that cleans and builds the sources from the command line. I'm in a windows environment.
I found this reference and followed it: http://www.support.code-red-tech.com/CodeRedWiki/HeadlessBuild
I added these folders to my path (as described in the manual)
C:\LPCXpresso_7.1.1_125\lpcxpresso\bin
C:\LPCXpresso_7.1.1_125\lpcxpresso\tools\bin
C:\LPCXpresso_7.1.1_125\lpcxpresso\msys\bin
I tried to execute: <product> -nosplash -application org.eclipse.cdt.managedbuilder.core.headlessbuild -cleanBuild all -build all -data c:\git\project
I don't know what to fill in for product. I tried lpcexpressoc and lpcexpresso both don't work. The command is not found, I couldn't locate any command or batch file ending in 'c' in the path folders anyway.
Any tips on this? I'm using the latest LPCExpresso version (7.1.1).
Simon
3 返答(返信)
1,282件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Oct 03 00:43:00 MST 2014
Quote: mspahr
How do I open a command prompt window?
Your favourite search engine would be a good place to start - you'll get lots of hits! For example:
http://windows.microsoft.com/en-gb/windows/command-prompt-faq#1TC=windows-8
1,282件の閲覧回数
lpcware
Content originally posted in LPCWare by mspahr on Thu Oct 02 16:33:38 MST 2014
1,282件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Tue Apr 08 08:12:06 MST 2014
The latest information on command line building can be found at:
http://www.lpcware.com/content/faq/lpcxpresso/building-projects-command-line
LPCXpresso Support
