Check Heap & Stack size during debug
714件の閲覧回数
lpcware
Content originally posted in LPCWare by Deepak Bansal on Tue Oct 09 02:46:47 MST 2012
How can I check heap & stack size during debugging.
I am using LPC1317 with Keil 4.54.0.0
620件の閲覧回数
lpcware
Content originally posted in LPCWare by whitecoe on Tue Oct 09 03:07:46 MST 2012
You likely to get more help with toolchain specific questions by checking the tool vendor's own support systems - this is after all the LPCXpresso forum, not the Keil forum!
Have you tried checking the Keil docs or posting on the Keil forum?
http://www.keil.com/support/man_arm.htm
http://www.keil.com/forum/
HTH!
