Content originally posted in LPCWare by CodeRedSupport on Tue May 25 01:16:47 MST 2010
In real terms, you have a Debug Port (DP) related connection or power problem.
This error means a read of the DP CTRL/STATUS register has determined there is a problem with the DP clock or power domain(s). This is one (or more) of CDBGPWRUPREQ, CDBGPWRUPACK, CSYSPWRUPREQ, CSYSPWRUPACK, or ORUNDETECT.
You can refer to the ARM document "ARM® Debug Interface v5.1" (DSA09-PRDC-008772) for more information.
CodeRedSupport
