Calling my Assembler program from C
851件の閲覧回数
lpcware
Content originally posted in LPCWare by acelink1 on Sat Mar 01 04:39:43 MST 2014
Hi Guys, can someone please explain how I jump to my .S assembler program from within a new C Project.
As you guys know when creating a new Xpresso C project the C program creates the LPC4357 startup code and then has an infinite
loop at the end.
How do I jump to my assembler program just before the infinite loop. I have no idea how to do it. I'm not a C coder, I'm an assembler coder.
My assembler program is called _start:
And thanks for your support guys, I really appreciate it.
Pete :)
2 返答(返信)
833件の閲覧回数
lpcware
Content originally posted in LPCWare by acelink1 on Sun Mar 02 01:12:30 MST 2014
Thank you TheFallGuy:  I try it at work on Moday.
Pete :)
833件の閲覧回数
lpcware
Content originally posted in LPCWare by TheFallGuy on Sat Mar 01 10:31:43 MST 2014
extern void _start(void); // declare the function
_start(): // call the function
