C++11 Projects
C++11 Projects
lpcware
Content originally posted in LPCWare by micronpn on Tue Mar 08 12:52:13 MST 2016
Why the C++ project wizard doesn't permit to set C++11 standard if the g++ compiler supports C++11?
lpcware
bump
lpcware
Content originally posted in LPCWare by micronpn on Wed Mar 09 04:24:36 MST 2016
Yes, I already did it, the question was only about the wizard.
Massimo Manca
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Mar 09 03:36:25 MST 2016
An oversight. We'll investigate fixing for the next release.
In the meantime, you should be able to change in the Dialect settings for the compiler in Project - Properties.
LPCXpresso Support
