Building a project with LPC4370 in release mode - problem
1,006 次查看
lpcware
Content originally posted in LPCWare by JoeE on Sat May 24 09:47:08 MST 2014
by building my project in release mode, I get two error messages that the files -llpc_board_nxp_lpclink2_4370 and -llpc_chip_43xx are not found. Where should they be located and where can I find or get these files?
JoeE
974 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Sat May 24 09:58:47 MST 2014
You need to build those libraries in Release mode too.
http://www.lpcware.com/content/faq/lpcxpresso/change-build-config
974 次查看
lpcware
Content originally posted in LPCWare by R2D2 on Sat May 24 09:58:25 MST 2014
Should be imported and built in your workspace...
See: http://www.lpcware.com/content/faq/lpcxpresso/linker-cannot-find-library
