Build project from scratch
lpcware
Content originally posted in LPCWare by anhdung88 on Tue Sep 23 19:14:29 MST 2014
Could anyone tell me how to make a project from scratch, I mean that I want to create makefile, designate toolchain by my own, not the one generated when using built-in menu of LPCXpresso.
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Tue Sep 23 23:32:17 MST 2014
The same as any other version of Eclipse...
File->New->Project
And choose C/C++->Makefile project
You will also need to create the debug configuration yourself, but of course, you will know that...
lpcware
Content originally posted in LPCWare by anhdung88 on Tue Sep 23 19:24:38 MST 2014
I want to clarify a bit more about "using built-in menu", I mean I want to use standard Eclipse project wizard instead of Xpresso project wizard, but for the same purpose making a project to LPC chip target and can be built, debugged like Xpresso project wizard does.
