Broken hyperlink in CodeRed Knowledgebase
lpcware
Content originally posted in LPCWare by larryvc on Tue Mar 22 21:39:05 MST 2011
Hi CodeRedSupport,
There is a broken hyperlink (have to copy/paste URL) at http://lpcxpresso.code-red-tech.com/LPCXpresso/node/34.
Delete this thread if you wish.
Larry
lpcware
Content originally posted in LPCWare by larryvc on Wed Mar 23 00:36:52 MST 2011
I wondered about that as I know about the Wiki but was getting to the old knowledgebase on occasion.  This ones fixed if only for sake of consistency.
It would sure be a pain in the... to fix all those old links in the old posts.
Thanks for the clarification.  Good Morning to you Good Night to me.
lpcware
Content originally posted in LPCWare by CodeRedSupport on Wed Mar 23 00:22:00 MST 2011
Thanks for this. Now fixed.
However, you should note that, as per http://knowledgebase.nxp.com/showthread.php?t=55,  the original LPCXPresso knowledgebase is no longer being maintained. It has simply been left in place to allow for the links to it in old forum posts.
Our FAQ's can now all be found at:
http://support.code-red-tech.com/CodeRedWiki
CodeRedSupport
