Break display format value
2,315 次查看
lpcware
Content originally posted in LPCWare by blasiis on Wed Jul 21 05:16:27 MST 2010
Where can I find to configure the value display format when I am breaked.
I need the hex format !
I cannot find this setting !
http://file///C:/Documents%20and%20Settings/Stefano.PORTORICO/Desktop/format.bmp
4 回复数
2,258 次查看
lpcware
Content originally posted in LPCWare by blasiis on Wed Jul 21 23:21:28 MST 2010
Quote: CodeRedSupport
Sorry, eclipse seems to have no way to change the format of variables as displayed in tooltips - only the display in the register, variables, etc views.
OK :mad:
2,258 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Wed Jul 21 14:01:13 MST 2010
2,257 次查看
lpcware
Content originally posted in LPCWare by blasiis on Wed Jul 21 05:32:53 MST 2010
All this value is already set ti hexadecimal but the display value i decimal !!
2,257 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Wed Jul 21 05:20:55 MST 2010
See the knowledgebase entry "IDE Config : Default display formats" at:
http://lpcxpresso.code-red-tech.com/LPCXpresso/node/53
[login required]
CodeRedSupport
