Appending text file
Appending text file
lpcware
Content originally posted in LPCWare by Rithus on Sat Mar 15 04:53:28 MST 2014
I am new to LPCXpresso. I wonder if i can append a text file on the pc drive using the usual c code?
This is my text below however is doesn't seem to be able to append any text file and when i run the program, i notice that the program will be stuck in the fopen append function. However it is working perfectly fine when i use the read and write function. May i ask if there is any other way to append a .txt file?
This is my code:
FILE * pFile;
pFile = fopen ("C:\\LPCDATA.txt","a");
fputs ("hello",pFile);
    fclose (pFile);
Thanks in advance:)
