Adtrim
Adtrim
lpcware
Content originally posted in LPCWare by Albert on Wed Aug 03 06:35:52 MST 2011
Hi all,
Someone can say the utility of ADTRIM register of A/D converter? I didn't understood the manual.
Thanks!!
lpcware
Content originally posted in LPCWare by NXP_USA on Fri Aug 19 15:22:17 MST 2011
For the LPC176x/5x product, user has the option to change the offset value using the trim bits. The default value for trim setting is initialized by the bootcode and can be changed by the user to vary the offset. See the Datasheet for the offset value.
Thanks.
